Jet-Jaguar
So, I've put together this strat. I followed the wiring diagram here:
http://www.dimarzio.com/sites/default/files/diagrams/3sbm_1v1t_3dpdtonononseriesphase.pdf
Now, when I was done with the wiring, I tried using a multimeter to test connectivity. The signal was doing weird things, but I was getting impatient so I decided to go ahead and put it on, string it up, and see what happened.
What I found was that when I turn the tone up (that is, cut the least out) the sound goes out. It's the weirdest thing. When I was testing it out with the multi-meter in my lap, it must have been moving the tone knob, causing the signal to cut in and out.
So, does this mean I need a different tone pot? Or is it more likely that I messed up the wiring?
