tone control problem
Mark W
Okay, I wired up my strat with the 2 SD STKS4's and TB14 in the bridge as per SD web page with one volume 2 tones 5 way switch.
the TB14 has no tone control? Can't tell by the diagram and it doesn't work.
Neck and Middle work fine, neck being upper tone and the middle being lower tone control.
Thanks for all the help
That's the vintage Fender wiring, with no tone control for the bridge pickup...
There will be one unused tag on the switch...join this to the wire coming from the middle pickup's tone control.
can I just connect the two tabs with a wire on that side? that is the unused tag and the one going to the tone control?
