TO'd Flamed Maple neck finished
fdesalvo
The face of the headstock has 5 coats of TO finish sanded with micromesh.
This is what 7 coats of TO looks like when finish sanded with micromesh.  It looks like it's been dipped in glass.
This was after the first coat was applied.  I finished the fretboard with 4 coats and finished it to a satin texture.  It's very slick - just as much as my other neck with an ebony board.
....... is TO a wipe on or spray on material ????? that looks really sweet ...... it looks real slick .....
Tru Oil is a hard finish, and it does satisfy W's requirement on necks that require one (assuming it's put on enough to actually protect it)
That really is a fantastic finish. I didn't think Tru-Oil could turn out that nice.
So... what's the downside? Does it stink? Is it sticky? Does it wear quickly? Are tone worms allergic to it? Does it attract ants? Will the dog chew it down to the truss rod if you leave it out?
...... lol, so what are all the coating options for necks, and what would be the pro's/con's of each, i want a smooth & glossy finish that is durable and low maintenance, my neck does have a white binder and a Rosewood fret board, any thoughts ??? ......
There are a huge number of finishes available.  If you're finishing it yourself, and want to keep it simple, there are a lot fewer, with varying levels of wait time and difficulty.  Read the sticky post at the top of the DIY Finishing forum.
But here's a quick'n'dirty approach to answering your question:
1.  Tru-oil, as illustrated above.  Easy to apply, but long-ish cure time.  To get as many coats as you want so you can buff it out to a high gloss, you could be at it for a couple weeks.
2.  Behlen's Master-Gel - from what I've seen in others' posts here, it gives similar looking and feeling results, with shorter cure times.  Also very easy to apply.  One coat every few hours, cure for a day, bam, your in business.
3.  Nitrocellulose lacquer (available in rattlecans).  Also longish cure times, highly toxic, but a classic - and easy to repair, since the new application will melt into the old coat.
4.  Catalyzed polyurethane in a rattle-can (search for Alsa Killer Cans).  Tremendously toxic, but flows on smooth and cures very rapidly.  Also very durable.  A bastard to repair because it cures so hard.
good luck.
Bagman
What DeathByMaxDangerousBagFly said. Although, he did leave out a popular option here, which is no finish at all, except I don't think that's an option in your current case. Something to think about for the next build, though. There are a few nice things about that choice. First, the money you save on finishing will often pay for some fancy exotic wood, which will not only make you happy, you'll be the envy of all your friends and enemies both. Second, some of those exotic woods must be felt to be believed. I mean, something like raw pau ferro or bubinga is just sex. Finally, you get them faster. Finishes have to cure, so you're looking at a 6 to 8 week lead time if they're not busy, while unfinished exotics can ship as soon as they're fretted.
