NovasScootYa
After years of being a stickler for not applying a finish to most exotic neck woods I've concluded applying around 6 coats of lacquer to most exotic wood necks is almost as necessary as having to apply a finish to maple...
The added thickness of the finish coat makes the neck feel fuller and play better especially for optional profiles and a neck finish adds to tone. The dimensions of exotic wood necks that require no finish are the same dimensions as maple necks which are intended to be finished with polyurethane, etc. Likewise the thickness of the finish applied to a body is also taken into account as the finish coat can raise the bridge height .010 inch. In the case of low end Fender bodies the finish can be .020" plus...Yes a bit of the slick feel of an unfinished neck will be gone but in time it'll be better than ever.
Another reason to apply a finish to an exotic wood neck is most exotic woods will contract and expand with weather changes although not as much as maple.
Finally another reason to apply a finish to most exotic wood necks is it elevates the problem of finishing just the face of the headstock in order to protect a decal.
