The
CAGED system is a very easy concept and a great system for expanding on where chords you know are.
in order to perform this method you need to know these things:
A "C" shape chord such as open C
An "A" shape chord such as open A
A "G" shape chord chord such as open G
An "E" shape chord such as open E
A "D" shape chord such as open D
You must also recognise the shapes of barr chords. If you have no idea what an E shape bar is then this will probably confuse you.
An understanding of where notes are on the fretboard and knowledge of scales helps but is not necessary. Aslong as you can find your root note then this is a piece of piss.
ok so what is it? what use is this for learning the neck?
Simply put the
caged system is a tool used for finding inversions of the same chord on the neck. Such as if we wanted to play the C chord in different places on the neck; the
CAGED system tells us where the next closest shape is.
CAGED isn't just a word, it is a specific formula for knowing where the closest inversion is in relation to what shape you are on.
C in the word
CAGED refers to the C Shape chord. and A to the A shape and so forth. This is a set order that cannot be changed. If you are on a G shape chord the the closest higher in pitch is the E Shaped chord and so on.
Here is an example of how it works.
You start by recognising what
SHAPE you are using, for instance instead of playing open G play a G bar chord. Most of you will go to this shape:
G Major -
e----3----
B----3----
G----4----
D----5----
A----5----
E----3----
If you haven't guessed yet, this is an
E shape chord. so we are on the E of the word
CAGED. This means that if we want to find the next closest G major chord we move along 1 space in the formula. We were on E in cagEd, now we move to D. So the next G major is the D shape bar starting on the closest root of G from our previous chord:
G Major - D Shape
e----7----
B----8----
G----7----
D----5----
A----------
E----------
So we are now on the D of
cageD moving along we start again on the C shape.
G Major - C Shape
e----7----
B----8----
G----7----
D----9----
A----10---
E----------
So we are now on the C of
Caged, and you repeat this process right along the neck.
Obviously if you want to find the next chord lower in pitch you reverse the process.
Here is the
CAGED system starting on the open C chord. If you can spot all the different shapes you will see that is Spells the word
CAGED
the C Major chord.
e----0--------3--------8--------8--------12-----
B----1--------5--------5--------8--------13-----
G----0--------5--------5--------9--------12-----
D----2--------5--------5--------10-------10----
A----3--------3--------7--------10---------------
E-----------------------8---------8----------------
C        A       G       E        D
This works for every chord anywhere. When it comes to chord extensions it becomes a little bit trickier. This is where a good knowledge of scales and how chords are constructed comes into play
Here is a
CAGED method for the Cmaj7th chord. A good exercise is to try working one out for yourself.
C Major 7th
e----0--------3--------7--------8--------12-----
B----0--------5--------5--------8--------12-----
G----0--------4--------5--------9--------12-----
D----2--------5--------5--------9--------10-----
 C        A        G        E         D
