Hi guys, thanks for the kind comments.
More details as follows:
All hardware is black
Body:
Hollow Carved Top Mooncaster
Scale: 25-1/2"
Wood: Quilt Maple / Maple on Maple
UC Front Laminate: LT1842
Contours: Contoured Heel
Binding: Black Binding
Top Finish: Bengal Burst
Back Finish: Black Burst
Neck:
Style: Superwide Strat®
Neck Wood: Wenge
Fingerboard Wood: Ebony (Black)
Nut Width: 1-7/8"
Back Shape: Wizard
Fret Size: 6105
Tuner Ream: Schaller (25/64" 11/32")
Radius: 10-16" Compound
Scale: 25-1/2"
Fret #: 22
Pre-Cut Installed String Nut: GraphTech White TUSQ XL - Earvana Nut
Inlays: Mother Of Pearl Dots
Side Dots: Mother Of Pearl Side Dots
Been working on the neck and headstock today, so as you can see i've destroyed my warranty within hours by modifying the headstock shape and inserting an inlay.
I've also burnished the neck.
A couple of blemishes on the headstock finish to sort tomorrow, then on to wiring.
For anyone else deciding on a Mooncaster, the following might help:
A standard right angle Switchcraft toggle switch DOES fit in the lower horn without much difficulty, but you will need the recessed nut (bought separately) due to the body thickness. This also means that long shaft pots are required.
