The Graceshredder V in progress I - the neck
graceshredder
First things first . . . the neck.  I had to dress the frets before anything else, so I taped off the fretboard, leaving the frets exposed, with the blue painter's tape.  Easy to remove and leaves no residue.  Then I took steel wool and lovingly and laboriously removed all the lacquer from the fret wires.  It is surprising how much was on those frets, but with the 'glass-like' look of the neck I guess I shouldn't have been surprised.  I carefully examined the frets with a magnifying lens to make sure the lacquer was completely removed.  Nice.  Frets clean and no scratches.
Then I decided to install the tuners, truss rod cover, and decal.  The little guide that Sperzel provides was a great help in the hole placement.  You know, no matter how many times I drill holes in a headstock, it still makes me a little apprehensive.  The blue tape you see on the drill bit gives me perfect depth, so there's one less worry.  The decal I installed by carefully taping and marking the exact center of the head from the tip of the truss rod to the tip of the headstock.  Then I took a piece of regular scotch tape and stuck it on my shirt and removed it two or three times to make it less sticky.  This piece I then used to pick up the decal itself.  Then I carefully marked the exact center of the decal so I could line it up with the center of the headstock.  I peeled off the protective backing, placed the decal just where I wanted it, and then smoothed it down by pressing on the scotch tape I'd used to pick it up with.  After pressing the decal firmly onto the surface, I then peeled off the 'less-than-sticky' scotch tape.  Cool.
Awesome!! Looking forward to see it finished, you have about 2 days to complete it before I start flooding messages to you complete it :laughing7:
This one is going to look amazing man! GotM material for sure :icon_thumright:.
