Eric Banjitar
My banjitar is still my primary instrument, however I have a new idea, a banjar.
Here's the plan: Start with a inexpensive tele neck. Cut away about a 1/4" of the neck perpendicular to the fretboard (making the neck skinnier and flat on one edge). The flat edge will allow me to glue an extension onto the side of the neck from the heel to the 5th fret. This extesion will be for the 7th drone string. I will then build a body modeled after a tele and route for the banjo head. I will next modify a banjitar tailpiece to hold a seventh string. The banjar will have two pickups a loller 7 string single coil and a schatten BJ02 transducer pickup. Both pickups will run down through a stereo 1/4" phone jack to a splitter and then to two amps, one electric and one acoustic.
Because this is such a crazy and unique idea, the first one I build will be done as inexpensive as possible. If the prototype works as I expect to, then we go top-shelf on the wood choices and build a really fancy one.
My banjo friend say "go for it", my guitar friends are mixed, no one cares what drummers think. What do you think? Any advice, suggestions, comments, questions or donations are appreciated!
