Punxsutawney
I've recently purchased a solid Warmoth telecaster body (5 lbs 1 oz). I'm considering an all ebony neck, modern construction, fatback profile and 1 3/4" nut width. A neck like that is probably going to weigh a bit. I'm inclined to think telecaster bodies are more prone to neck dive unfortunately, because there's no horn above the neck, which extends towards the 12th fret, where the strap would be secured further from the centre of gravity (pulling the neck up). I also believe weight is a factor of course, but might have less influence on the outcome. Fortunately, the body is more on the heavier side, but is it enough? What do you guys think? Does anyone have a heavy neck with a telecaster body? Do you suffer from neck dive as result?
