TBurst Std
Someday, I'll be able to restart my Tele project. With the delay, I have started to consider an additional option.
Here are the givens, top route Tele
Neck and bridge single coil pickups. Both pickups have a tap on the coil. Tapped is standard Tele, full is closer to P90.
Going to use a reversed and angled Tele control plate. I will be using a 4 way switch for neck, neck bridge parallel, neck bridge series, bridge.
Option 1: use a 3 way mini switch located between the vol and tone pots. This would allow both pups tapped, neck tapped and bridge full, and both pups full.
Now thinking about option 2: use push pull pots so that I can individually select tapped or full.
Option 2 would allow the option of having neck full and bridge tapped that option 1 doesn't account for. Not sure how usable an option that would be in either series or parallel.
Thoughts? This guitar will be used live on stage, so practicality does matter.
Let me know.
Let me know.
