SustainerPlayer
Like most of my other projects this started out as something quiet different.
I may have the world record in owning guitars equipped with the Fernandes sustainer system. I have been through many factory models and DIY's as well.
One of the latest was this Fernandes FR85s - a Japan model I bought used from a guitarist who originally bought it in Japan.
The garden tools and such are not part of this story. [blush]
But as I experincede before - after adjustment, setup, fret leveling etc. I still didn't bond with it. So I had to choose between selling it ... or do something with it ...
So I did. It should be obvious that when my best and most used guitars all are my self made Warmoth partcasters then it would be a good idea to transplant the sustainersystem to a Warmoth.
Then this appeared in the Warmoth Showcase:
Strat body with 8 ball graphic. Alder - actually a first for me having used basswood, swamp ash and mahogany before.
It went into the basket with this neck:
Maple neck (also a first) with Pau Ferro fingerboard (my preferred I have 3 others with this wood). 6150 frets (normally using 6130) and finished in black - matching the guitar´s design. I normally have unfinished necks on my builds.
I have not made photos of the building process. So it will only be "best of my iPhone" of the almost finished result. It is my 10th Warmoth build. But #9 isn't finished yet. So it's to early to celebrate that.
Enough talk ... now the photos:
The bridge pickup is changed to a Dimarzio PAF pro.
I have made a basic setup and cut and fine adjusted the nut. It just needs some fine adjustment of the sustainer system itself.
Oh - and I need to order a battery box. The ones I had laying around were a diffrent size from what Warmoth routes for. Thats why it has the elegant blue painters tape solution right now. Haha.
I also need to find out whether I want to continue with the higher 6150 frets or grind them down to the same height as 6130 when I make the fret leveling.
I'm also contemplating a Tremol-No for this. Although the Wilkinson VG-100 is a very stable solution in itself. Actually this very unit I have had on different guitars since 2006!
And then I probaly put my Roland GK-3 pickup on this also. It seems to fit nicely with scheme.
