Max said:I would suggest a 4 way switch, with a push-pull pot for that kill setting. I wouldn't want my guitar cutting off by accident mid-show.
Yep. Just thought he might not want to drill extra holes. :icon_thumright:NLD09 said:Max said:I would suggest a 4 way switch, with a push-pull pot for that kill setting. I wouldn't want my guitar cutting off by accident mid-show.
or a separate kill switch.
Alfang said:Hey Minions, why don't you go look at the seymour duncan website and find the schematic you want.
The only thing your doing with this post is being lazy, anyone here that would help you, would spend a few minutes looking through some schematics and posting a link for you.
Do it yourself. it's not that hard.
tfarny said:I don't think you'll find that schematic because honestly it's not a very good way to get multiple tones. The reason is that it would be very, very easy to accidentally turn off the guitar mid-song. If you want that kill switch position, okay, but it doesn't sound like you do. I'll draw it up for you if you really want that, but I don't have a camera here so it would have to wait until tomorrow.
Is this for a strat? If so, here's what I have on my own strat - it gives every possible combination (except neck and bridge in series, no middle), looks stock, and the only 'dead spot' is in series, position 3. No dead switch position unless you're using the funky extra tones. http://www.unofficialwarmoth.com/index.php?topic=7713.0
The "blend pot" is just the standard 500k pot with a push-pull.
Another good option for your super switch is the five-tone tele diagram below.
One other thing you might consider, and probably what I would do if next time: Just figure out what five sounds you need the most and wire the super switch to give you those. On a strat, maybe just for example you never use 'middle only' or 'bridge only' and those could be replaced by 'neck / bridge series out of phase' and 'neck / middle in series in phase' just for instance. You could wire up a switch like that no prob.
tfarny said:Is this for a strat? If so, here's what I have on my own strat - it gives every possible combination (except neck and bridge in series, no middle), looks stock, and the only 'dead spot' is in series, position 3.
minions said:Does anyone have a diagram for a Super 5-way with:
1 - Neck
2 - Neck and Bridge in Series
3 - Neck and Bridge in Parallel
4 - Bridge
5- (off)
Thanks.
pkell said:minions said:Does anyone have a diagram for a Super 5-way with:
1 - Neck
4 - Bridge
5- (off)
Thanks.
Neck and bridge in series or neck and bridge in parallel would be very noisey...not hum canceling...i presume it is an SSS guitar. If you had a HSH you could do this with hum canceling! Check out the attachment.
