Glimmer
On a recent string change, I switched from GHS Boomer 12s to Thomastik-Infeld Jazz Bebop 12s, just for the hell of it. I've used T-I flat wounds before and wanted to give the round wound Bebops a try. To my surprise strings 5 and 6 were significantly quieter than those of the preceding set and the G string a bit louder, as the gauges of those strings possibly suggest:
Boomers
012 016 019 DY28 DY38 DY52
Bebops
P12 P16 P20 BB28 BB36 BB50
I'm wondering, does lighter string gauge = lower volume, or is it possibly due to the materials used, or a combination of the two, or ... ? Chords, in particular extended chords, played with the Bebops sound really balanced – the lows don't dominate and you seem to hear each note equally well, which is odd, because the low E and A strings are definitely not as loud. On melodies however I find that I have to adjust my picking so that higher and lower register notes have a roughly equivalent volume.
Might I attenuate this by raising the pickup height a bit on the E-A-D side? Don't know if I'm going to like the Bebops well enough to want to use them in the future (they're pretty expensive as well) but would like to give them a chance.
One final question: I tend to experiment with a lot of different strings before settling on one or two that I like best. I know that changing gauges can necessitate adjustments to the guitar. Should I expect to have to adjust pickup height with each string change as well?
Boomers
Bebops
