Jerryatrick
I’m in the process of mod’ing a strat. I noticed that the location of the middle and bridge pup is slightly biased toward the high end and a bit shy of the low E. If as planned, I put a new neck with wider string spacing at the nut I think the low E will be moved far enough from the magnet to cause a noticeable volume drop in that string.
Does this sound like a plausible approach or not really? Thinking this would require routing the upper edge of the pickup cavity like 1/8 then cutting the pick guard and drilling new holes for pup screws to accommodate the upward shift.
