Starting to set up my conversion neck on my strat.
I have 3 stage staggered tuners installed with no trees and a Warmoth installed TUSQ nut with 9/42 strings.
I have gone over the neck with my straight edge and a fret rocker set the truss rod for some slight bow and set the bridge saddles for height and radius using this video below (actually have action set higher than I like for now). Everything seems good as far as the frets being level.
I am getting a ton of string buzz both open and fretted. Mostly on the G string but also on the D and A.
A-lot of it seems to be coming from behind the nut (not all of it). I don't think I want anymore neck bow as when I use a capo and the last fret method to check it...it's spot on.
I am wondering if my need for light gauge strings and conversion scale is requiring me to use string trees?
I am 100% a function over looks guy..so if trees are the easy answer I don't mind having to use them...but obviously it seems redundant to use staggered tuners and trees at the same time.
I have only dusted the nut with some graphite but have not adjusted anything on it (let me know if this is a must do).
I would assume unless the stock nut is cut for 10's that the strings if anything are tight in the nut.
Currently have no neck shims installed.
Any tips or suggestions? I really want to learn how to do this myself.
[youtube]https://www.youtube.com/watch?v=tnVuvoj3WXs[/youtube]
