BrotherJack
So, this post is half question and half 'what I did to make my Ibanez RG more to my liking'. I replaced the 3 way switch with a standard (import) 5 way switch, and tried to get the following:
Pos1: Bridge
Pos2: Bridge + Neck
Pos3: Neck
Pos4: off
Pos5: Neck with coil split
Or any variation that gives me all 5 of the options above. I tried a couple three or four things that I thought would work, but I kept overlooking some element of the wiring and would end up with either coil split in more positions than I wanted, or off in more positions than I wanted, or no coil split option. So my question is, if anyone knows how to get what I want out of a STANDARD 5 way switch? If so, pls to explain.
Failing at getting what I really wanted, I wired up as follows (standard import 5 way switch - see here for great diagram on what's hot and what's not in what position, 2nd one down the page covers the import 5 way I used: http://guitarwiring.blogspot.com/2011_01_01_archive.html):
1 = Neck Pickup Hot
2 = Bridge Pickup Hot
3 = Neck Pickup Hot
C = Output
C = Ground
3 = Secondary coil wires for neck
2 = open
1 = open
That gets me close, except the switch positions start at 5 and work back (which is fine, I don't find it particularly un-intuitive that we start in position 5 with the neck pickup and work back):
Pos5: Neck
Pos4: Neck + Bridge
Pos3: Bridge
Pos2: Bridge + Neck w/ coil split
Pos1: Neck w/ coil split.
I had thought about adding a 200k resistor wired to the output wire where "1 = open" above, which would should dampen the output just slightly for neck and neck+bridge positions, leaving the bridge only and all single coil options wide open/direct to output jack (ie: hotter signal when in bridge-only, or any of the single coil positions), but since I already have an on/off/resistor 3 way switch on the same guitar, I skipped that part.
Anyway, there she be - for your information, or if you know the answer to my first question, for your thinking about.
Thanks,
Jack
Pos1: Bridge
Pos2: Bridge + Neck
Pos3: Neck
Pos4: off
1 = Neck Pickup Hot
3 = Neck Pickup Hot
C = Output
C = Ground
2 = open
1 = open
Pos5: Neck
Pos4: Neck + Bridge
Pos3: Bridge
Thanks,
Jack
