Staggered Sperzels.. What order?
line6man
ACELUEK said:
line6man said:
Shouldn't it be obvious?
Ahh, why would I have asked. I guess I'm not at smart as you. Plus, this is my first strat type neck.
I don't mean to sound like a smartass or anything, but i think it should be kind of obvious if you look at it.
The higher tuners are further away from the nut, so the string needs to be down lower.
Mor Paul
I figured it out by thinking the string tree lowers the top two strings, so the posts would be shorter to compensate.
ACELUEK
I just looked at the neck and that is the way I installed them. I did also think about the sting trees on the bottom strings. Thanks guys!
