Squier Troublemaker Tele Body, Loaded With Custom Warmoth Pickguard & Tonerider Pickups
LushTone
Up for sale is a Squier Troublemaker Telecaster body, fully loaded with custom wiring and tortoise pickguard.
The tortoise pickguard was ordered from Warmoth and I custom cut the notch for the pickup ring.
The pickups themselves are Tonerider Birmingham Alnico V humbuckers, which are medium output at about 7.2K neck and 8.5K bridge. These pickups are specifically designed to sound great in the split coil function as well as classic humbucker.
The pickups have been wired with two 500K Bourns volume pots, and two 500K Bourns push/pull tone pots for split function (using .47uf Mallory capacitors).
Other electronics specs are a 3-way toggle switch wired for traditional pickup selections, and a Switchcraft 1/4 inch output jack.
The bridge has been upgraded with adaptor bushings and a Kluson USA made ABR with unplated brass saddles (stock tailpiece). Very high-quality parts that fit this body perfect.
Included in the listing are the original “Nashville style” import bridge with the 6mm M8 posts.
Also included are a gold neck plate and neck screws (The neck plate is an older plate from Warmoth so it has some wear, but functions well).
Weight on this loaded body is lower than normal at about 6 pounds and should yield a 7 1/2 to 8 pound guitar with a traditional neck.
Will ship in a well-packaged and sturdy box via USPS Priority mail.
