Some background- I've been planning on getting a new guitar for a while, so I've been renting some of the "standards" to try to get a feel for what I want. I loved a black Les Paul studio (I'm looking for the slow Buckethead tone), and was about to pull the trigger when my dad pointed out this site. I'm ecstatic about building a guitar, but I've never so much as changed a pickup, so I need some very basic help. I'm an engineering student and love tinkering (primarily computers), so soldering, etc, is no problem, but have no knowledge about guitar hardware so I was hoping to get some advice to try to avoid stupid mistakes.
Now, the questions-
1) It seems like the standard on this site is 25.5 scale, but I want to go with 24 3/4. Is the LP body scaled up to fit the longer (default) neck, or is it the same size as the Gibson body?
2) I want to do the standard Les Paul wiring. Is this a good schematic to follow? http://www.seymourduncan.com/support/wiring-diagrams/schematics.php?schematic=2h_2v_2t_3w_phase
Also, what does it mean by "Phase Switch"?
3) When attaching the neck, is any glue used, or just screws?
4) What kind of jack should I get, mono or stereo?
5) Are holes for attaching the strap holders already drilled?
6) The neck builder says that you can get the neck finished the same as the guitar, but I don't see any option to do that. How do I flag that I want that done?
7) What is the coaxial wire in the wiring kit for?
8) I don't have any spare parts, so I need to get everything that I would need for the build. Here's my planned purchase- am I missing anything other then pickups and the jack? Also, any comments or critiques on my choices would be greatly appreciated.
Model: Carved Top Standard LP
Orientation: Right handed
Wood: DL Quilt Maple on Mahogany
Pickup Rout: Humbucker (Neck), None (Middle), Humbucker (Brdg)
Controls: Volume 1 (LP), Volume 2 (LP), Tone 1 (LP), Tone 2 (LP), Upper Toggle Hole (LP)
Bridge: TOM/STP, Ang Pock
Top Finish: Green Dye
Back Finish: Black Gloss
Jack Rout: 7/8" Side
Binding: White Binding
Neck Pocket: Strat® Shape
Countours: Contoured Heel
Stud Install: Use inserts from bridge on order
Style: LP
Construction: Conversion Angled 24 3/4"
Neck Wood: Mahogany
Fingerboard Wood: Indian Rosewood
Orientation: Right Handed
Nut Width: 1 11/16"
Back Shape: Standard thin
Fret Size: SS6230 (Stainless)
Tuner Ream: Gotoh/Grover (13/32", 11/32")
Inlays: Pearloid Sharkfin
Pre-Cut Installed String Nut: GraphTech TUSQ
Finish:
Radius: Straight 11"
Scale: 24-3/4 in. Conversion
4x knobs
4x 500K Audio Taper Pot
3x Gotoh SG38 Tuner, Left, Chrome
3x Gotoh SG38 Tuner, Right, Chrome
2x .047 caps
2x Humbucker Mounting Rings
Gotoh Stop Tail Piece
Gotoh Tune O Matic Bridge
3-way switch
Wiring Kit
Thanks for your time and any help you can provide,
Graham
Now, the questions-
Style: LP
Neck Wood: Mahogany
Nut Width: 1 11/16"
Finish:
4x knobs
2x .047 caps
3-way switch
Wiring Kit
Graham
