Soloist Rear rout dimensions
Jhroden
Hi everyone. I’m doing a new soloist build and need some help. Does anyone know or can send me a link to the rear rout dimensions. I’m doing some prep work and need to do some measurements. Length, width and depth. I need to make an accurate template of the rout itself. Thanks in advance. -Jer
I’m doing a father and son build. We are wiring a custom SSS harness similar to a Jackson PC1 knob layout. I need the dimensions while my body is on order. Length, width, depth. -Jer
Take some blue painters tape and tape across the cavity one direction, then tape across at 90 deg angle. Then with a new exacto blade, then cut tape following the edge of the cutout. Then carefully put the tape on a piece of stiff cardboard. Then you will have an accurate representation of the pocket... :icon_thumright:
I think it's best to get the body in your mits before soldering.  I'm not saying there inconsistency, but if you want to perfect, I'd wait and follow Dangers advice.
