DMRACO said:i admire the test but it would be good to have it with both guitars playing the same set up. Sounds like the 1st guitar had some gain to it.
Cagey said:Same here, and I agree. The body is not without effect, but it's nowhere near as influential as many believe.
Cagey said:If it were an acoustic, or had vibration-sensitive pickups on it such as a piezo system of some sort, then I would agree. But, the pickups are magnetic and only sense the movement of the strings. Any audible reflections off or vibrations of the body only exist for your ears, not the pickups, unless the vibrations are so pronounced that they affect the strings. For instance, banging the guitar on the floor would cause strings to respond to the body enough that a magnetic pickup would sense it, or having amplification so high that the body vibrates in sympathy to the sound reinforcement system, creating a feedback loop (See Jimi Hendrix, Ted Nugent et al) :laughing7:
fdesalvo said:I have had several W bodies of both construction - even down to the same types of woods. I'll tell you with confidence that the neck is the single most important factor in what we perceive as "wood tone".
WindsurfMaui said:...So his tone was all in his rack...
