Satin Nitrocellulose?
Elderer
Anyone has done anything with this type of...color/cover on their guitar bodies?Tips,pictures of your work would be welcomed.
I had an old Kramer that had Nitrocellulose lacquer and it turned yellow after about 12 years. I've used Duplicolor lacquer with SprayMax 2K clear and Alsa urethane with SprayMax 2K clear. My favorite is Alsa urethane paints with SprayMax 2K clear. If you use lacquer paints and a 2K clear, you still have to wait for the lacquer underneath to fully cure (that's even if you use a 2K clear on top) or else it will still be too soft to play and you'll develop all sorts of defects in your finish. The guitar below is not even a year old…
This is from my fingers/nails resting on the body as I pick:
This is from resting the guitar on a guitar stand:
Click below to see what it looked like before I started playing it every day:
http://www.unofficialwarmoth.com/index.php?topic=13332.0
