Satin neck worth it?
  • Thread starter Thread starter Cederick
  • Start date Start date
C
Cederick
I've had my satin neck for a couple of weeks and the satin feel is all gone. It was my first even satin finished neck so I was at first very impressed, but not anymore
And I am that kind of person who has NO problems with sticky gloss necks; one of the guitars I've played almost all the time for 10+ years, has never been sticky unless some friend comes around and tries the guitar and I have to wipe it clean as soon as they stop playing. And sometimes not more than a minute...  :sad1:
And no other guitar I've had has ever been sticky, no matter what material used in the finish, ever. I barely even knew about sticky necks until I let people try my giutars...
So, does satin finish really get "worn down" that fast, no matter how "unsweaty" your hands are?
EDIT: slipping my finger from back of the headstock to the neck really exposes how "sticky" the neck has become
I've got a couple of Fenders with satin poly on the neck and those took years and years to polish up. And I've got a Warmoth satin neck that took a few weeks to get to the same point - though none of them are sticky, I have to admit. I think it's just a soft finish. Try some 0000 steel wool on it, maybe.
Nah, that would just go through the finish and expose the wood at some point, so I wont bother.
It's not unplayable at all, I don't have a problem with it. Kinda feels like a regular finished neck, but I was expecting the satin feel to hold longer... Well, if I'm getting another Warmoth finished guitar I'm NOT getting satin
Get raw instead! Or, get one of the gloss finishes, which are poly, and rough it up. I think it'd take longer to polish up.
I'm one of those guys that hates sticky necks. My hands sweat a bit while I'm playing and a gloss surface just exacerbates the problem. So I went with a satin finish on my Maple/Maple neck.
The same thing you're describing happened on mine. It took a good year or so before mine got glossy though, so I'm a bit surprised that yours did it in a couple weeks.
I use 500 grit sand paper to rough the finish up again. I just take the paper and with very very VERY soft pressure rub the back of the neck until the shine dulls. Really light grade steel wool or a rough polishing cloth would have the same effect.
The real solution, IMHO, is Canary!
:icon_biggrin:
Using 0000 steel wool is common practice. Everyone does it at some point or another, when then end up with a glossed up satin. It would take a considerable amount of effort to sand down to bare wood with fine steel wool.
