NQbass7 said:Also, no batteries! Stick a 9V adapter on it and get a OneSpot. Better for the environment.
hannaugh said:Art so far. I might do another version yet.
StubHead said:I like some battery capacity, or else it's worth putting a bit of change into a decent power supply. I love those OneSpots or the equivalent Rocktron "OnTap" etc., but when you start running a series of things off of a single OneSpot and some polarity or grounding issues arise, yeeks - if you're out on a gig, a handful of 9v. batteries FIXES the problems right then and there because it isolates each effect. I don't even really know what technically goes wrong, but it sure can suck. When you see a band that's supposed to start at 9 and the guitarist is still crawling around on the floor at 9:45..... "hmmm mebbe this'll work...." :tard: :sad1: :icon_scratch:
And if you're not toting one of these at the very least, don't say "it's not my fault...."
http://www.sweetwiter.com/store/detail/SS6Block/
Death by Uberschall said:Just get a Voodoo Labs PP2+ and end all your power supply worries. I tried the 1-Spot and it was a humming nightmare in my setup because its a switching power supply, you want a linear power supply.
Other than the 24v adapter that goes with my Reverbulator pedal, everything else on my board is powered by the PP2+, including my switching system. All of my effects stay on all the time. The PP2+ is that good.
