Super Turbo Deluxe Custom
Epic Member
I did some sidework for a friend who owns a music store, so I made an arrangement to get paid in gear.
I acquired this:
2011 American Special Precison Bass, brand new, never sold, hung on the wall for 3 years.
I turned it into this:
The relic'ing was done via 0000 steel wool taking all of the gloss down to a dull matte, then 220 sanding around the usual wear areas, then back to the steel wool to remove any sanding marks and smooth it out. It was about this time I opted for a heavier distressing and ditching the white pickguard for a black one.
I also wanted something a little more custom, so I added a MM style humbucker in the bridge. I used a trim bit in my router to make an MDF jig from an existing MM route in another bass.
....then I made a thicker jig to compensate for changing depth with multiple passes to route the body.
....then did the appropriate measuring for center lines, squareness, etc., lined it up, and routed that pickup.
This is after one pass, and it will be taken down to the depth of the hole in the center.
Voila!
I also added a Gibson style 3-way right angle toggle.
With a 1/2" Forstner bit, I drilled through the pickguard in the body.
...removed the pickguard to view the switch placement.
...and routed for the switch using what was basicially a P-90 jig from a few years earlier.
The finished layout.
This bass also came with somewhat of a cutout for the truss rod adjustment, but is an insult after getting used to the truss trench that Warnoth offers, so I made one. Some consider them an eyesore, but the less work involved for simple adjustments, the better IMO.
I also did threaded inserts for the neck and bridge attachments.
Lastly, the electronics. This came standard with the "Grease Bucket" tone circuit. After much reading, couldn't really tell you what it does. But I decided to recreate it. It's basically a 2nd (.1 mf) cap on a different portion of the tone pot. I do long shaft 500k pots and .047 caps on most rewires, as well as create a metal buss for all component grounding so I don't have to solder to the pots.
Let the questions, comments, criticisms begin!
I acquired this:
Voila!
