Right Nut On Left Neck?
Heft
I'm considering upgrading the neck on my first warmoth build. There is a showcase neck that looks perfect, but is left handed. Can I stick a R3 nut on it instead of a L3? It's 1-11/16.
Thanks.
You probably could attach it without too much difficulty using the bolts rather than sticking it on.
However the side dot markers will not be visible as they will then be on the side of the neck closest to the floor in normal playing position.
