Replace Fender American Standard tremolo with Gotoh 510 tremolo.
Unwound G
This topic has probably been covered but I will ask again.
Checking the body rout, I noticed the stud posts are of the same distance for both but the hole for the tremolo block is bigger for the 510 trem.
Will the replacement work if I put a Gotoh 510 trem into a body routed for an American Standard trem ?
The studs of the Gotoh are a different dimension. And a two post American standard rout would need adjusting with a file or similar to accomodate the Gotoh's arm bushing. That is the difference.
So it is a doable mod rather than a complete no. YMMV, caveat emptor and the usual small print applies.
If it is a Warmoth body you could ask them to do it for you. Before the 510 trem rout was offered as a standard it was a $45 option. The quilted purple to clear burst strat linked in my signature was done exactly that way.
