OK, real close to pulling the trigger but want to ask a few last questions.
I'm going to order a rear routed tele (falt top) Mahogany back with maple top, rear routed. I'm planning on DiMarzio Area T pickups. They have a solderless system but it won't work on a rear route, pots are to short. There in lies my first question, 1) Do I really need the long shaft pots? I don't want to do any of the wood work in the control cavity (I've seen some strings on how to do this to "thin out" the wood but perfer not to). 2) If I need a longer pot, then don't I need a longer 3 position switch? I haven't seen these on line. Where can I purchase if needed? 3) The age old question, do I really need to shield? 4) Seems like a silly question but since I'm mounting the pickup directly to the wood, do I really need springs? The last set up pickups (EMGs) had threads on the pickup. If the pickup has threads and the screws thread into the wood, then don't the springs really become uselss? The pickup height is set and does not float on the sping. Or, should I ream out the threads on the pickup and let them float on the springs?
Thanks for all your help.
