vikingred
Ok, so here is my build thread: http://unofficialwarmoth.com/index.php?topic=25545.0
Never really thought about it but regular strat short-shaft CTS 250k pots DONT FIT all the way up through the back cavity to the top of the body. Ugh. And worse, I don't have any long-shaft Les-Paul type pots on hand.
Here is the body:
I've already thoroughly copper-shielded the back cavity. Would it be insane to try to drill a countersink, or use an exacto to carefully cut out a hole on the inside of the cavity the size of the entire short shaft pot body so it would fit through to the top? :binkybaby: I think I could pull it off but it would certainly be a pain. I figure I need a little more than an 1/8" to make it work and get that nut on the threads. Danger is that if I drilled or cut through or even got too close it could be a disaster.
It's only 2 pots for this build, 1 master tone, 1 master volume.
I've looked around and alternatively I'd suppose I'd have to order a long-shaft Les-Paul type pot, it's like 3/4" but I don't like them, and they're not the dimple-back old-school CTS mojo impedence-matched pots that I have.
I really wanted to finish this build this weekend. What would Jimmy Page do? What would Cagey do?
What say? :sad:
Here is the body:
What say? :sad:
