Viper Jazz
Howdy, all! I'm building a semihollow strat (wenge top, mahogany body, maple neck) and have run into a few minor speedbumps in the wiring process. After quite a few cuts on my thumbs, the guitar is now shielded. Yes, I've read the arguments for and against, but I had already bought the copper tape at that point.
My question is where to attach the ground? It's a fixed bridge and I'm using the technique described here where a strip of copper tape is attached leading from the ground wire to the body of the guitar itself (see pic). So one end of the ground wire will terminate under the bridge, but where does the other go? Do I attach it to the copper shielding itself in the control cavity, or does it go where all the other grounds go (soldered to my vol pot)? Also, can you see in the pic if there are any ground loops? All ground leads from pots are terminating at the vol pot right now. Also, I'll have a strip of copper leading out of the cavity to a screw hole for the pickguard, but do I only need to do that for one of the holes, or for all of them? And does that provide a ground for the shielding of the pickguard and the shielding of the cavity?
Lastly, my main problem right now is that I can't get a ground wire through the hole from the bridge to the body cavity (again, see pic)! Because it's a semihollow body, it seems that when I thread wire into the hole, it gets lost in a cavity instead of getting pushed through the 2nd hole. At least that's what I think is happening--all I know is that I can thread about 5 ft. of wire into the bridge ground hole w/o it coming out at the body cavity hole. Any ideas? I tried a coat hanger but it was too stiff and thick. Halp!
