Question before place the order
fournij
Hi
I'm finally close to post my order to warmoth :
NECK :
Style: Angled Strat®
Construction: Warmoth Pro Angled
Neck Wood: Maple
Fingerboard Wood: Indian Rosewood
Orientation: Right Handed Reverse
Nut Width: 1 11/16"
Back Shape: Standard thin
Fret Size: 6105
Tuner Ream: Schaller (25/64", 11/32")
Inlays: Abalone Face Dots
Pre-Cut Installed String Nut: GraphTech Black TUSQ XL
Finish: Vintage Tint Gloss
Radius: 10-16" Compound
Scale: 25-1/2 in.
Fret #: 22
BODY:
Model: Standard Stratocaster®
Orientation: Right handed
Wood: Flame Maple on Mahogany
Rout: Rear Rout
F-Holes: None
Pickup Rout: Humbucker (Neck), None (Middle), Humbucker (Brdg)
Controls: X-T-T-5-X-X
Bridge: Wilkinson Tremolo
Top Finish: Tobacco Burst
Back Finish: Transparent Brown
Jack Rout: 1/2" (12.70mm) Side Jack Hole
Binding: Vintage Tint Masked Binding
Neck Pocket: Strat® Shape
Countours: Contoured Heel / Tummy Cut / Forearm Countour
Stud Install: Use inserts from bridge on order
I have a questionsbefore to do the checkout :
Is there any tuning issue with the mix of angled strat neck, GraphTech Black TUSQ XL and Wilkinson Tremolo ?
If somebody something that could be a problem with the neck and body I'm planning to get, please let me know.
thanks
Graphtech nut, and locking tuners, and having no string tees are all good places to start. If you are still have tuning problems when using the wilky, then first make sure that the strings are broken in and stretched properly. Locking tuners stay in tune best when the string is tuned sharp and than tuned down to pitch, which is the opposite of ordinary tuners. If you are still having issues after that, then have the nut properly slotted so that it does not grip the strings. By following these tips I was able to get my 6 hole trem bought from the Warmoth site to stay in tune.
Thanks
because some people complain about the angled neck strat and tremolo on this topics :
http://www.unofficialwarmoth.com/index.php?topic=11521.0
do yourself the favor and make those 6105 frets SS6105.
and you shouldn't have any issues with your setup.
