Two-part question:
Can you get a DPDT toggle switch that is the same size as a Les Paul 3-way pickup toggle ... in other words not a 'mini' toggle switch?
If so, would it fit in a hole drilled for a standard LP tone pot?
I'm thinking about replacing the neck tone control on a LP with a DPDT to do coil swapping and making the bridge tone a master tone control. Would end up looking like a Gibson BFG.
