Hi everyone,
I'm a newbie gearing up for two Warmoth builds -- an alder J-bass, and a black korina VIP -- and could use some finishing suggestions. The J-bass will have a birdseye neck finished by Warmoth, but I'll be doing the finish for the neck of the VIP myself (the neck is also black korina). I love wood color and figure of the VIP, and want the body and neck to have the same look, ultimately with a satin finish. For the J-bass, I'm going for a tangerine-colored stain, then a clear satin finish there as well. I've done one mahogany body with Minwax wipe-on poly and had pretty good luck.
I'm particularly curious about using wipe-on poly or aerosol lacquer over WATCO Danish oil and/or pure tung oil. My experience with tung oil so far hasn't been great, but given the figure of the VIP (pic below) it seemed like a good choice. I haven't used Danish oil before, but thought it might be a good option for the J-bass (and maybe the VIP, too).
I figured using an oil finish would bring out the figure, but wanted to add a hard topcoat for protection and for validating the warranty on the neck for the VIP. Are their issues applying poly or lacquer over (thoroughly dried) oil? Would it be better to forget about the oil and just go with straight-up poly/lacquer (or vice versa)? For lacquer, I'd probably have to wait until the spring to spray it outside since I'm working in a small basement that also houses a gas furnace.
Thanks a lot!
Kieran
Thanks a lot!
Kieran
