I have experienced blushing during the application of the sanding sealer on the guitar I am finishing. Because I am an amateur, I kept adding additional coats of sanding sealer after I first noticed the "haze". My thought was that additional coats would burn into the previous coats and make everything alright. After 8 coats of sealer I sanded the surface thinking that maybe while I am leveling the surface the haze might go away. Fail! I sanded away most of the hazy clouds but what I am left with is a smear type of look and white specs within the pores of the grain!!!
Mahogany body is what I am working with. After sanding with 220 grit sandpaper I tried adding clear grain filler to get rid of the haze. Fail!
Since I did not follow the correct action, which is immediately apply blush eraser, am I screwed? I about ready to call it quits by either continuing with the sanding sealer process with the flaw or spray painting over the sanding sealer with a solid color.
PLEASE HELP!!!
PLEASE HELP!!!
