Daze of October said:
guitartom said:
Ok. Are you getting a sitar sound with the nut locking pad off? Also, take a breath. This is part of the coolness about assembling your own guitar. Once you figure this out you will have learned a bunch. Once you get back to me we can try 2 other things.
Yes, still sounds like a sitar. It just rings out loud 'n clear! :sad1:
I'm obviously no luthier, but given everything I've tried, I don't know how it could be anything but the nut or a fret. :tard:
OK - so its not the locking pad pushing the string against the V. Look by your pictures - your high E looks really close to the 1st fret. It could be the picture angle. You may need to shim only the treble side (I would use a .25 half shim) and not the whole nut.
If shimming the treble side only does not work - then I would look at swapping the nut. If you are really adventurous you can try swapping one from a guitar that does not buzz. Just make sure the size (RX) and radius is the same.
The reason I say not a high fret is because you are only getting the sitar effect on your E string and not the B and E strings.
One last thing - check out Rich Harris's site ibanezrules for setup info. It is the best resource for setting up a floyd based guitar.
