Sovereign_13
Playing around with switching schemes in my head for a Bass VI with 3 single-coil-sized humbuckers (as suggested by the rep from DiMarzio). All three are dual-rail pickups, and I was thinking it might be neat to be able to switch between series and parallel for each pickup.
The advantage, in my mind, would be to be able to choose parallel coils for a more articulated tone and series coils for when clarity is less important than oomph.
Without drilling extra holes in the pickguard (or the body) to accommodate extra switches, I've come up with two different schemes to get series/parallel switching:
What I'm calling "Jaguar-style" uses the traditional Jaguar/Bass VI 3-switch plate. Instead of simple on/off wiring, I would wire each pickup as "series/off/parallel". This has both the advantage and the disadvantage of the most pickup combinations, by allowing each pickup to be selected individually and in each mode. What I don't know is if I'll ever want the "all 3" or "neck and bridge" options, or if those options would even be useful on that type of instrument. That many options can also lead to tricky on-the-fly pickup switching.
The other option I call "Strat-style", although it's really more of a Strat/Jaguar hybrid. With this option, I would trade the Jaguar on/off switches for series/parallel switches and use a 5-way selector on the upper bout. The advantages here are that panel-mount DPDT switches are easier to find than DP3T on-on-on or DP3T on-off-on switches, and the overall switching scheme is a little more compartmentalized. The disadvantage is that you lose out on a couple of pickup combinations (probably not a big deal).
For either case, the traditional "bass strangle" (or "thin") function will be handled by a push-pull switch on the tone knob.
Thoughts?
Thoughts?
