I have a neck pickup on a bass that stopped working. All wires are still commented. I find it hard to believe a pickup would malfunction. Do you think it's jus the pot?
Given the pot is the only moving part in the circuit, I'd say it's the most likely point of failure assuming you haven't poured battery acid all over the axe. Certainly it's the easiest part to swap out.
does your bass have a toggle switch? sometimes when a pickup stops working it's because the toggle switch is not making contact properly. I find it weird that a pot would go entirely bad all of a sudden.
