shanejw said:
I want to do a 3 humbucker les paul with a humbucker in the neck and bridge and a humbucker sized p90 in the middle. how are you doing your pickup switching?
Several options, I will list some.
#1 master volume,master tone, single/series switch. when in series; I have the normal 3way toggle on the upper bout. when single, I have the signal routed to 5wayblade, with the p90 in the middle position.
#2 1 volume for each position. mastertone. regular 3way for bridge/neck+bridge/neck, and another minitoggle for either the signal from the regular output, the p90, or both.
#3 same as above, but with mastertone and master volume.
#4 the toggle/slidswitch can be mounted in the pickguard, or even cleaner-looking; in a pickupring.
#5 1 volume for each pickup, master tone, regular 3 way for the humbuckers. pushpull to choose either the humbuckers or the p90, pushpull to engage the p90 in whatever the other switches are.
My favorite is the version #2, but #`1 works GREAT, but you need a big rout for that in your les paul, to fit the 5way blade (or a 5way rotationknob, just like PRS). you do need a 3pole 2way switch for #1 though.
What I would like to do, is #1 with mastervolume,mastertone, and a pushpull to engage the p90 anytime, and for the other pothole the volume/blend for piezo, eventhough I dont use it, but this is the most versatile you can get without screwing up the looks
