Pickguard pickup holes
jrfox92
I'm planning on starting a Warmoth Strat project which will involve 3 Dimebucker pickups, although if there are any suggestions to getting a better sound closer to that of a hofner (such as what jamie hince of the kills plays) it would be helpful. The issue i have, though, is that for the mid pickup i can't find any possible way to get a perfect fitting cover unless i choose to cut, which i'm not sure of doing that either since I don't think i have the appropriate saw blade. Thoughts?
I'm not sure what you're asking.
If you are using the same pickup in the neck, middle and bridge positions, what makes the middle pickup different from the neck and bridge?
I googled the Dimebucker, and I'm not sure what cover you're talking about, either.
I fixed the issue, but it was a matter of the Custom guitar builder graphic thing that warmoth has and i couldn't edit a fit for a middle pickup, but i changed to a different pickup and worked it out.
