Pick up wiring
teh_grimness
I'm building an HH tele, hopefully soon, and I wanted to set it up with a 5 way switch so that it worked like this:
1- full bridge
2- inner bridge coil
3- both humbuckers
4- inner neck coil
5- full neck
So as the have the effect of a push/pull coiltap without the push/pull pots. Mind you, I won't be doing the wiring, but I wanna make sure I get what parts I need to pull it off (5way or push/pull)
realistiically, i only need a full bridge p/u, im not even setting up a tone pot, just two volumes. i play mostly extreme metal/punk/hardcore/prog metal and i dont NORMALLY use much else other than my bridge. BUT i like having some options in case i feel froggy and want some weird tone for something lol.
