Fat Pete
Little bit of progress...
New switch tip and new Graphtech saddles. I've used this type of compensated saddle before and they've intonated ok. It's not just to look at though so if it doesn't work well enough I'll go another way.
Attached the neck - 2 strings on before tightening it up to check the alignment and wiggle if necessary. Looks spot on.
One thing I'm not so happy about is that there's unfinished wood visible on the cutaway side of the neck socket.
Closer view
Spotted this when it arrived but wanted to wait until the neck was properly screwed on before deciding what to do about it. It's not that obvious - at a glance you'd take it for shadow and it's not in the most often viewed area - so I'll probably either touch it up or just forget about it, but what do you guys think? Worth talking to Warmoth about? Clearly I've done too much to it to return it.
Next, lots of holes to drill in my paintwork...
Closer view
