Re-Pete
I don't own many pedals, have off loaded quite a few over the years tho.
What I have left - and will use - I want to house in a rackmounted drawer in my home studio.
I want to buy a good quality isolated power supply. While I won't be buying many more effects pedals I want to future proof my drawer by getting a good quality PS & one that may be able to take digital effects (I understand they do take quite a lot of current draw when used) if I buy them in the future.
A lot of my effects can be done 'in the box' from the Kemper but some of those on their default settings are pretty mild. I guess, however, I should delve deeper into the settings there before passing judgement on that section of the Kemper.
I also want to try & use an 18v connection for an EMG - ES-18 power pack which powers guitars I have that house active electronics. EMG themselves dismiss the concept of an external power supply for the ES-18 (they don't make them & claim they haven't found one to recommend) as they believe it introduces noise to the signal chain, but strangely, have included a power socket in the ES-18 pedal.
Now: if I buy a good quality power supply and daisy chain up 2 x 9v outputs into 18v and both of those are isolated (or the power supply comes with a dedicated 18v isolated output), I may have a chance of avoiding noise. If it fails, well, I tried and go back to using 2 batteries inside the ES18. (BTW, just curious, what's the mA of the usual 9v battery that goes into the pedals?)
I've looked at VoodooLabs, I've looked at TRex, I looked at Cioks & even MXR/CAE MC403. My head is starting to spin :tard:
One thing I'm getting hooked up on is the mA ratings?
Most of the older pedals were very light on the current consumption.
But I do have an old Electro Harmonix Little Big Muff pedal that might need some extra mA?
I'm guessing the 18v 'experiment' I want to try, will have a best chance of succeeding if I get an outlet with higher mA than lower? (I'm assuming the higher the mA rating, the more consistent & 'clean' the power will be?)
I simply don't know enough about both the pedals I want to hook up, or the mA current implications on electricity!
If I get a 9v or 18v outlet with a ridiculous high mA but the pedal only needs say 80mA, will it affect the pedal's performance (maybe even damage it?) or will it just give the pedal a cleaner performance ability? :dontknow:
I apologise for asking all this. I should have learnt this sort of theory years ago, but didn't. I'm not a technician or electrician, so the theory has never been a necessity.
When I have been doing speaker cabinet matches or any other electrical match up, I usually go conservative & try to match things up exactly.
I'm now in the process of tidying up my home studio and want to formalise a more modular approach to the various parts of it, so that means getting a pedal drawer up & running. I'm sick of tripping over cords/leads.
Many thanx to folks who can add a bit of advice here. :icon_thumright:
