allium_sativum
When building my new Strat I decided to try a passive clipping circuit. I looked at products like the Black Ice Overdrive (from Stewart Mac) and the Dirty Rice (has-sound.com). I found some information on the web but not much, so here is what I learned and a few sound clips.
So what is a passive clipping circuit and how does it work? In this case it is a diode wired to act like a switch, when ever the voltage is high enough the diode turns on, any signal higher then this voltage is bled to ground. When the voltage drops below the required voltage the diode shuts off and the signal acts as if the diode is not there. If the voltage is not high enough the diode never comes on. With one diode you will get asymmetrical clipping of the signal, if you add a second diode in the opposite orientation you will clip the signal symmetrically.
Because most diodes require .70 volts to turn on and the hottest pickup I know of is the DiMarzio X2N with a rated output of .500 volts most diodes will not work. To make this work you will need high output pickups and a Schottky diode with a low forward voltage like the BAT46 from STMicroelectronics.
To connect this circuit you will add 1 or 2 diodes like you would a tone capacitor (i.e. one end to the pot, the other to ground). If you use 2 diodes make sure that the strips on the diodes are opposite each other. I would also use a 250k audio tapered pot, a linear taper will drop the voltage to fast and will be hard to control. A 500k pot only worked for about 1/3 of a turn on most setups I tried.
I also learned that the impedance of the amp or effects peddle you are plugged into effects how well the clipping works. I was plugged into a Crate solid state amp and it did not work well at all. Most tube amps should work fine.
I also learned 2 diodes make any other tone controls on the guitar useless. With one diode the tone controls only work on the unclipped part of the signal.
For leads the output is less clipped. The more the strings vibrating the more voltage output from a pickup. 1 string = lower voltage.
So what does it sound like?
Here are some clips. They were recorded on a Line6 Tone Port UX2, all amp models and effects were shut off. I used the middle (Duncan Cool Rails) and the bridge (Duncan Custom Custom) untapped in series. The clipping is set to max. No settings were changed other then the diodes between samples.
www.allium-sativum.com/graphics/Guitar/PowerChordsClean.wav
www.allium-sativum.com/graphics/Guitar/PowerChords1Diode.wav
www.allium-sativum.com/graphics/Guitar/PowerChords2Diodes.wav
www.allium-sativum.com/graphics/Guitar/Lead2Diodes.wav
