bagman67
Epic Member
Steve_Karl said:Update:
The denatured alcohol with a putty knife is working the best.
Maybe your original water-based finish has a shellac component to it. Shellac dissolves in alcohol. D
Cagey said:Finish removal is never any fun. I think most folks only do it once. Then the next time it occurs to them to do it, they have a real come-to-Jesus meeting with themselves about how much the body is worth and whether a new finish is gonna be that much of an improvement. Even if you only charge yourself minimum wage, by the time you strip and refinish it, a used or new body with an already acceptable professional finish is either cheaper or damn close to it, and is always faster.
Bagman67 said:Steve_Karl said:Update:
swarfrat said:Normally heat works on peeling paint off but I wonder if it'd soften it up for the solvent? (Obviously don't soak it in flammable liquid and hit it with an 800F heat gun. Boom! But the other way around might work.
Steve_Karl said:I've heard it said many times that when you wet it down with Naphtha it's looking almost exactly like it will look after the final clear coats.
How accurate is that really?
Cagey said:Very close. Naphtha isn't as thick as a clear coat of solids so there's a slight difference in refraction, but as far color and chatoyance, you're there.
Cagey said:First thing I thought of when watching that second video was the glue let go between body halves, then I see in the comments I'm not the only one who noticed. If you blow it up to full-screen, then it's obvious.
Heat guns are for sissies. Methylene Chloride. That's the way you do it. Better living through chemistry :laughing7:
TonyFlyingSquirrel said:Naptha, & matches!
Removes the paint, and relics at the same time!!! :evil4:
