animal control
I'm sure this has been asked before but I must not be using good search criteria. I'm looking for a pedal that will allow me to switch between two amps with as little signal loss and noise as possible.
Tonar8353 said:I have a Voodoo Labs Amp switcher that I took out of the box tested it out and put it back in the box and never used it again. If you want I’ll make you a good deal on it.
Paul-less said:
Superlizard said:
Justinginn said:If you keep the clean [amp] always on like Tonar suggested you get your normal clean tone plus added definition when distorted (clean always cuts better).
Cagey said:Justinginn said:If you keep the clean [amp] always on like Tonar suggested you get your normal clean tone plus added definition when distorted (clean always cuts better).
No kidding. I'm always surprised at the YouTube videos where somebody is "reviewing" an amp/guitar/pickups and they've got the reverb cranked to where it sounds like some sort of '50s science fiction flick and they're feeding it with a Big Muff Pi or a Tube Screamer or some other kind of mega-breaker-upper thingy. WTF? You're supposed to draw some kind of conclusion from that? Well, I do. And that is: this guy wouldn't know tone if it bit his ear off.
yea, I want to hear the amp, not the effects with itkböman said:Cagey said:Justinginn said:If you keep the clean [amp] always on like Tonar suggested you get your normal clean tone plus added definition when distorted (clean always cuts better).
+1! And don't forget the endless brainless knee-jerk blues licks and bends...
Has anyone tried this? I am pathologically paranoid about anything in my signal chain that loses the connection between pickup and amp and then promises to "recreate" it.lidesnowi said:Try this http://www.tonebone.com/tb-switchbone-using.htm
