KaiserSoze
Hola. I'm equipping a dual hb guitar and going for a very traditional paf tone. I like the fralin pafs but am told that using them with a coil tap configuration is do-able but not the best result. I can go to the high output hb model and it would work fine or maybe....
I have an old alembic strat-o-blaster circuit that installs at the input jack. I can retrofit it and add an on-off switch that would boost the signal when I have it in single-coil mode. That way I could have the pafs of 8 or 9K the way I want but could boost the signal at will so the single coil sound isn't so weak. Would this work okay? and would the circuit just add a boost to the humbuckers as well? Thanks
