probably need an update to java rather than turning it off. A lot of stuff on the net uses java and if you aint updated you can get crashes and stuff. :cool01:
Last couple of years I've been using a Danelectro Blue Paisley. Ill have to try out a Rat, sounds interesting. I'm looking for something a little more bright and transparent for Tele/strat bluz tones.
To me, the rat is more of a distortion pedal. If you want to add a sheen to your sound with subtle tube break up, then I highly recommend the Green Screamer. The GS is a tube screamer clone.
The thing I like about the Rat is that it has quite a range. Subtle drive to all out chaos. It is probably considered by most to be a distortion pedal though.
