We are now announcing the November, 2017 Guitar of the Month contest! November's contest will be "Warmoth/professionally finished" and requires at least a Warmoth neck or body to qualify.
Please read the GOM rules, which have been refined, with some slight changes, and are posted in a sticky in this forum area.
Submissions must be sent, to uwfgom@gmail.com, and contain two images no greater than 1024x768, along with your description and details of the instrument. Send your submission in plain text email. Your photos must be attachments to the email. Your unOfficialWarmoth Forum user name must be included in the body of the email.
In turn, your images will added to this message, which is November's submission thread.
Submissions will be accepted until exactly 7 days from the date and time of this post, so get your cameras clicking!
As usual, discussion about the submissions can take place below.
Please do not post additional photos in any replies to this thread. Links to other UW threads or external sites are fine. Links will not be included in the entry descriptions.
Please try to stick to the entry requirements:
1024x768 pixel images maximum as attachments please, not embedded in the email or linked to external sites.
Include your UnOfficialWarmoth Forum user name.
Warmoth or other professionally finished instruments only this month.
Sorry, but entries that do not meet these requirements may not be included in the contest. If you're having technical difficulties, get in touch! (But only about contest entries please!)
Good luck, and may the best guitar/bass win!
Guitar #1 Axl12
Simple Riff Machine
- Body
Black Korina
Tobacco burst finsh
Carved neck back
TOM bridge route
Direct humbucker route
Single Volume control
- Neck
Roasted Maple with a Ebony fretboard
Mother inlays
Standard thin profile
6100 Stainless steel frets
No finish applied
- Hardware
Tonepros bridge
Hipshot locking Tuners
Earvana nut
- Electronics
Fishman Modern Fluence pickup
USB lithium rechargeable battery install in the cover
Guitar #2 kolsky
Mahogany VIP hollow body with flamed maple top finished in cherry sunburst with ivoroid binding,
Mahogany vortex neck with Indian rosewood fretboard and stainless steel 6100 frets,
Graphtech resomax piezo wraparound bridge,
Seymour Duncan Alnico II Pro pickups with coil splits via push/pull volume and tone pots,
hybrid toggle switch for Mag/piezo combination,
piezo volume also has a mid range boost activated via a push/pull pot.
9v battery box located on the back
Stereo mag/piezo output,
Gotoh 510 18:1 tuners.
Guitar #3 -VB-
DBDHCARTLT
(Double Bound Dual Humbucker Candy Apple Red Thinline Tele)
Warmoth '72 Thinline Body
Alder
Candy Red finish
Super-Vee Blade Runner trem system
Pickups wound by hand in my garage
Bridge pickup: AlNiCo II, 43AWG PE wire
Neck Pickup: AlNiCo V, 42AWG PE wire
5-Way Oak/Grigsby switch provides full humbucker and coil-split options
Warmoth CBS Stratocaster Neck
Macassar Ebony on Flame Maple
Vintage Tint Gloss with Headstock matched to body
59 Roundback Profile
White Pearloid Diamond inlays
Metal headstock decal by Morning Print
Gotoh Magnum Lock Tuners
Black TUSQ XL nut
6105 Frets
10-16" Radius
Guitar #4 ctownsend
Body:
Warmoth Telecaster Thinline, Pau Ferro on Black Korina with white binding, clear satin finish
Neck:
Warmoth Telecaster Modern Construction Roasted Maple with Pau Ferro Fretboard and white binding
Parts:
Lollar Tele Special Bridge pickup
Lollar Tele Vintage Neck pickup
Emerson 4-Way Prewired kit for Tele
Glendale vintage "single-cut" bridge-plate non-magnetic stainless
Glendale "Twang" Intone Cutting Edge set
Glendale "Extreme" Fat Neck Plate
Glendale "Cold Rolled Steel" ferrules
Gotoh Vintage Tuners
Guitar #5 BigSteve22
Blackbird Telecaster
Neck:
Warmoth Telecaster,
Dark Ebony on Maple
24.75" Conversion Scale
SS6230 Frets, MOP Dots
Hipshot Open Back Locking Tuners
ZeroGlide Nut,
Rothco & Frost Headstock Decal
Owner Finished, Clear Satin Lacquer
w/ Black Lacquer Headstock
Body:
Warmoth Standard Telecaster
Solid Swamp Ash, (4 lbs, 0 oz.)
Satin Black Finish, Full Body Contours
Babicz "Z" Series Tele Bridge
Custom Engraving by DangerousR6
Rock Rabbit Control Plate
DangerousR6 Custom Neck Plate
Electronics:
Bill Lawrence, L-202TN, Neck P/U
Noise Free, Black Case
Bill Lawrence, L-298TL, Bridge P/U
Noise Free, Open Coil
Wiring:
4-Way P/U Selector Options,
"Gibson" Style Tone Circuit
Guitar #6 Ug Thump
Redward
Body:
Telecaster
Wood Mahogany
Bridge Tunomatic
Comfort Contours and Contoured heel
Finish Transparent Red Gloss
Pickups: P90 rails in neck, Seymour Duncan Distortion in Bridge
Both Volume knobs are Push Push pots, which allows Humbucker Series, Humbucker Parallel, or either coil.
Neck:
Warhead
Wenge Shaft, Figured Ziricote Fretboard
SS6150 frets
Standard Thin
Guitar #7 michael_mccallie
Body - Super High Grade Flame Maple on Chambered Mahogany, Tiger's Eye finish by Warmoth.
Neck - Roasted Flame Maple treated with gun stock oil, EVO gold frets.
Hardware - All gold. Wilkinson VS 100 Trem, Kluson Locking Tuners, Seymour Duncan Pearly Gates.
Guitar #8 Amigarobbo
Solid Alder body
Seafoam, err Foam Green Gloss paint job by Warmoth. Part of the Summer Special Screamin' deal!
Babicz FCH-4 Bridge
Lace Alumitone Pickups
Genuine Fender® Control Plate, Bournes pots with various pull pull series/parallel options
Custom Chrome Paisley Scratchplate by Quickguards.com
Maple/Pau Ferru neck, Clear Satin Nitro
stainless steel frets and cream face dots
Gotoh Lollypop tuners
Rotosound Swing Bass 66 strings
Guitar #9 ronios
Ronios RV1
The Neck -
Style: Warmoth
Construction: Gibson® Scale (24-3/4") Conversion Tiltback
Orientation: Right Handed
Neck Wood: Roasted Maple
Fingerboard Wood: Indian Rosewood
Nut Width: 1-11/16"
Back Shape: Standard thin
Fret Size: 6150
Tuner Ream: Schaller (25/64" 11/32")
Radius: Straight 12"
Scale: 24-3/4" Conversion
Fret #: 22
Pre-Cut Installed String Nut: GraphTech Black TUSQ XL - Standard Nut
Inlays: Mother Of Pearl Dots
Side Dots: White Side Dots
Schaller M6 machine heads
The Body
Custom shape carved out of a Warmoth solid mahogany body blank.
Professionally finished in Copper Pearl
Seymour Duncan Jazz @ neck.
Seymour Duncan '59 Custom/Hybrid at bridge.
Schaller Signum bridge.
CTS 500K volume
CTS 500K push/pull tone (coil tap)
Switchcraft gold 3-way toggle.
Switchcraft output jack.
Custom shape/custom cut pick guard.
Q-Parts Gold/MofPearl control knobs.
Guitar #10 e-turc
Ash core / Mahogany top
Lake Placid top Vintage yellow back and side
Bigsby with Classic Bridge with Vibramate
Classic neck and bridge TVJones
Volume and tone control
Vintage tint Maple with a Ebony fretboard
vintage white inlays
Modern Standard thin profile
6150 frets
vintageTuners
Earvana nut
Guitar #11 KnowTalent
Good WOOD
Fretboard/Neck:
Warmoth Goncalo Alves
Modern Thin C profile
6100 SS Frets
Sperzel Locking Tuners
White Side Dots
Body:
Warmoth Black Korina body
Chambered, 720 Neck Pocket
Contoured Heel
Select Black Korina Top
Warmoth Vintage Transparent Satin
Misc:
Gotoh/Wilkinson Floating Whammy
ZexCoil Hybrid Juicy 5 Mini Buckers
Reverend Bass Contour on Pot#2
Tone/Bridge Winding PP on Pot #3
Assembled by Joe's Music
Roseville, MI
Guitar #12 exaN
-Quilt maple on swamp ash body, vintage tint
-Standard thin maple/maple neck, vintage tint
-DiMarzio Chopper T + Twang King, 1 volume 1 tone
Guitar #13 macegtr
Warmoth-body:
Carved soloist with alder body and double laminated flame maple top
Copperhead dye in front, tobacco burst on back
720 mod and contoured heel
Ivoroid binding
Two EMG SA single coils, Seymour Duncan TB-12 humbucker in bridge (buffered by EMG PA2)
Modified Graphtech LB63 installed in Schaller Floyd Rose recess
Normal Strat control options used for volume for magnetic pickup (push/pull for humbucker coil splitting), volume for piezos (push/pull for two EQ-options), 3-pos select switch in between, one stereo output jack
EMG solderless 5-pos pickup selection switch
Battery routing for Gotoh single battery box
Additional cover plate for trem hole
Warmoth-neck:
Modern, standard thin birdseye maple neck with black ebony compound radius fretboard, cut from 24-fret to 23-fret to fit in
Scalloped, Stainless Steel 6100-frets, cream dots
Clear Satin-finish
Schaller M6 Locking Tuners
Schaller R3 locking nut
Gotoh hexdrive tool holder
Guitar #1 Axl12
Simple Riff Machine
- Body
Black Korina
Tobacco burst finsh
Carved neck back
TOM bridge route
- Neck
Mother inlays
No finish applied
- Hardware
Tonepros bridge
Earvana nut
- Electronics
Guitar #2 kolsky
Guitar #3 -VB-
DBDHCARTLT
Alder
Candy Red finish
Black TUSQ XL nut
6105 Frets
10-16" Radius
Guitar #4 ctownsend
Body:
Neck:
Parts:
Neck:
Warmoth Telecaster,
Dark Ebony on Maple
ZeroGlide Nut,
Body:
Electronics:
Wiring:
Guitar #6 Ug Thump
Redward
Body:
Telecaster
Wood Mahogany
Bridge Tunomatic
Neck:
Warhead
SS6150 frets
Standard Thin
Solid Alder body
Babicz FCH-4 Bridge
Guitar #9 ronios
Ronios RV1
The Neck -
Style: Warmoth
Nut Width: 1-11/16"
Fret Size: 6150
Fret #: 22
The Body
CTS 500K volume
Guitar #10 e-turc
6150 frets
vintageTuners
Earvana nut
Good WOOD
Fretboard/Neck:
6100 SS Frets
White Side Dots
Body:
Contoured Heel
Misc:
Roseville, MI
Guitar #12 exaN
Guitar #13 macegtr
Warmoth-body:
Ivoroid binding
Warmoth-neck:
Clear Satin-finish
