R
renzen
I'm having confusion about a wood-mount, rear electronic route strat.
I just put Bareknuckle 'Irish Tour' pickups (RWRP on mid) into a pickguard mount strat recently, and had no noise at all, clean, dirty, higher volume, etc. Was so leased that it seemed the right thing to do to put together another, using rear routed electronics... but no.
Wood mounted (with the tubing & foam) looks OK, and sounds fine on clean settings, up to reasonably loud volumes on tube amps. Bust when overdriven, there's plenty o' noise, like the worst s.c. p/ups and wiring I've heard/seen. And, despite continuity checks OK everywhere it should be grounded, there is a slight 'tick' sound on touching a grounded part (which again seems like the bad p/up thing, but these haven't been bad p/ups on the pickguard guitar at all -- they're great, in fact).
Tearing out hair seems less than helpful...
Has anybody had a similar experience, or have ideas about why this should be happening with an otherwise pretty decent build?
Thanks!
Thanks!
