brokebymonday
I'm having a strange thing happen as I'm spraying the nitro clear. It's becoming cloudy and splotchy. Has anyone encountered this before? :rock-on:
Bagman67 said:If you want to go super-ghetto, you can also just try shooting the surface with a mist of lacquer thinner to flow the coating enough to maybe make it release the moisture.
Tonar8353 said:I do not know what lacquer you are using but the best cure for the lacquers I use is to thin it with additional lacquer retarder. It allows the surface to stay open longer and then the moister will be able to escape before it gets locked in.
